| | | Forums66 Topics128,041 Posts1,055,593 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 25 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 25 | All, I have had no issues with my drive train. Drove my truck to town a month ago and brought it home and parked it under the lean to. Got in it this past Saturday and can't get it in gear? It just grinds. Its like the pressure plate is gone, no warning or anything. Has this happened to anyone else. I have a 54 3/4 ton dually with a 4 speed manual transmission. I've laid under the truck and had my son push in the clutch pedal without the truck running of course and all the linkage is working. I can see the throw out bearing move back into the pressure plate area. I don't necessarily mind dropping the transmission but I'm just wondering what else it could be? Are there synchronizers that could have went out in the transmission or is it just a simple clutch issue? Any suggestions or story's of how you may have fixed yours would be greatly appreciated. Thank you | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Sometimes the clutch will stick to the flywheel with light rust Can you shift it into gear with the engine off? If so Put it in gear Press clutch in Try to start it It usually breaks free because it can’t hold enough to move the truck But your problem maybe different but easy to try the simple things before taking stuff apart -s | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Warning the truck might also start and you will be driving unexpectedly So pick an appropriate surrounding and plan for that  | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | My 55 2 ton does the same thing from time to time. starting it in gear normally breaks it free. (might need to warm the engine up in neutral first so it starts easy!) | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | With the dust cover removed from the bell housing, have someone push the clutch pedal down fully (engine off) and slip a putty knife between the clutch disc and the flywheel. If that doesn't work, get the truck pointed down a straight road, start the engine with the trans in 1st. gear, push the clutch pedal down, and nail the brakes. One of these procedures will unstick the disc from the flywheel. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One of the attributes of living in the rust belt.
Ed
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Even though I'm just about all Chevy/GM, I do have a Ford Wrecker that I use as a yard truck (It was too good a deal to pass up, lol). If I let it sit too long the Clutch will stick. And it really sticks. I have to crawl under and break it loose as Jerry has described above. What I end up doing is put a wooden stick from the Clutch Pedal to the Seat to prevent it from happening.
By the way, anyone who wants to trade for a Chevy Wrecker, just let me know, lol.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Aug 2019 Posts: 25 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 25 | Thank you very much. That makes sense. I will check this out over the weekend. This solution will be a lot better than dropping the transmission for sure. BTW is the transmission held on with 4 bolts, 2 on each side and that's it or are there some across the top? I'll let you know what I find. Much appreciated gentlemen! | | | | | Joined: Aug 2019 Posts: 25 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 25 | putty knife did the trick! clutch disc was stuck to the fly wheel. | | |
