| | | Forums66 Topics128,139 Posts1,056,758 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | I welded a bunch of holes in the firewall. I ground down high spots with Grinder and then used a scotch brute pad to get it down a little more but still have a very slight hump should I spray high build primer on or dose anyone have a trick to make it more smooth? | | | | | Joined: Sep 2010 Posts: 1,714 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,714 | Pictures would help in describing what you have. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Grind or sand it more until it is smooth. A die grinder with a sanding disc works best. 120 grit for final smoothing.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
