8 members (Bisbee, 49Chief, DadsFirstPickup, D B Cooper, joe apple, Otto Skorzeny, cmayna, 1 invisible), 77 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
2 Offline
I welded a bunch of holes in the firewall. I ground down high spots with Grinder and then used a scotch brute pad to get it down a little more but still have a very slight hump should I spray high build primer on or dose anyone have a trick to make it more smooth?
back yard wrench turner
Pictures would help in describing what you have.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Sir Searchalot
Sir Searchalot
Grind or sand it more until it is smooth. A die grinder with a sanding disc works best. 120 grit for final smoothing.
