1 members (baldeagle), 40 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#1419550 08/05/2021 10:47 PM
Quick question: Are head bolts reusable? I have a 1954 235 that needs a ring job and I need to pull the head. Can I reuse them or do I need to buy new one? Thanks.
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0612.html
Engine Assembly - Cylinder Head - Step 1 and Step 4
(of course, read the rest of the Engine Assembly head-section in that manual)
Snowman 51 Never used a new headbolt. I wonder if you can buy a set of headbolt studs,I think you could get a better torque-up with studs. You would need to seal the block threads,could use a hard washer and high quality nut.
If the bolts clean up and look good, no reason you can't reuse them. If they are rusted and pitted, you might want to find another set.
AD Addict & Tinkerer
I just reused mine last year with no issues on my 235.
Phil
Project Journals
Stovebolt Gallery Forum
ARP has a kit P/N 155-4002. Kit for a F--d 427 SOHC 427. You end up with 4 extra short studs, washers & nuts but cheaper than purchasing open stock parts.
BC
1960 C60 pasture art
Fox Offline
These old stovebolts aren’t like the new LS engines which have a “one time only” torque to yield bolt that isn’t supposed to be reused.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1419941 08/09/2021 4:34 AM
Fox, I understand we aren't talking tty bolts, I deal with them at work, designed to tight to low torque then a given angle of further rotation & they do stretch.
Not saying 60 year old bolts aren't fine, however if you want to replace them studs look cool as well as more clamping force.
BC
BC59 #1420095 08/10/2021 4:36 PM
BC59 thanks for that tip on head bolt studs,have short block ready for a head.
Since I'm expecting to get a noticeable compression increase on the long stroke "216" I'm building, I plan to use studs instead of head bolts, and possibly a solid copper shim head gasket like the alcohol fueled blower engines use. I'll probably have to make my own gasket, by using a conventional one as a template.
Jerry, the Best Gasket #502C is copper. As I recall, it is embossed - dimpled around the cylinders - not a true shim, but I would think that should work for you, since it is designed to crush.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
