1 members (Gone), 180 guests, and 1 robot.
Topics128,183
Posts1,057,263
Members48,467
I have a 63 x mility suburban 4x4 K 10 ( task force truck) see EB' 63 in 63 burbs photos.
I am ready to replace the body mounts and then add a leaf/ refresh the spring assembly.
I cannot find any replacement mount kits for this vehicle. Anyone done this to a similar GMC or Chevy Factory 4x4 burb? All the mounts are differt from the front to mid truck and rear. Don't know how to post pics here.
Thanks for any help.🙏
Instructions are in the left margin of every page.
Can't see that on my phone....
You have to use a real computer. Sorry
got it thanks
Sir Searchalot
Sir Searchalot
Normally the words "Task Force" here means 1955.2-1959 era trucks. I assume you are using it another way to indicate Military.
pix Here are four pages to READ. pix
Flathead Ford and 55-57 Chevy engine mounts along with spacers/washers will give a made up mount that covers most body mounts requirement. If all else is not doing the job buy some liquid urethane rubber and cast your own or cut from rubber truck mud flap. Anchor motor mounts used to have a paper catalog that showed mounts in actual size but probably all is online now. Our latest go to mount is the S10 body mounts. Has a limiter tube in center and cups to limit squish. Thick so not suitable for mounting on top frame flange but great for AD cab mounting as it gets rid of shackle type or center plate mounting and can be shimmed for door alignment.
Evan
Many thanks guys. Thought I would have to improvise and invent.
I use the term task force trucks because years ago when I got the truck it came with a couple of photos, a brief history and the previous owner used the term government or task force truck. His notes said GM had a separate assembly line for the military, forestry service and fire departments. Apparently a farmer bought the truck at military auction in 1966, hand painted it yellow and painted a basket with fruits and vegetables on the doors. Unfortunately shortly later the farmer died and his widow put the truck in the barn. 30 odd years later the farm was sold and the vehicle was found. It ended up with the guy I bought it from 16 years ago in Canada. I stopped posting back in 2010. I will put up some newer photos of the project. Thanks again for having good ideas and sharing🙏
