7 members (55shaker, TUTS 59, KEVINSKI, ShopRag, Goach2, Maybellene, Gray_Ghost),
122
Mod | | | Forums66 Topics128,204 Posts1,057,298 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | I have a 63 x mility suburban 4x4 K 10 ( task force truck) see EB' 63 in 63 burbs photos.
I am ready to replace the body mounts and then add a leaf/ refresh the spring assembly. I cannot find any replacement mount kits for this vehicle. Anyone done this to a similar GMC or Chevy Factory 4x4 burb? All the mounts are differt from the front to mid truck and rear. Don't know how to post pics here. Thanks for any help.🙠| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Instructions are in the left margin of every page.
| | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Can't see that on my phone.... | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | You have to use a real computer. Sorry
| | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Normally the words "Task Force" here means 1955.2-1959 era trucks. I assume you are using it another way to indicate Military.  Here are four pages to READ.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Flathead Ford and 55-57 Chevy engine mounts along with spacers/washers will give a made up mount that covers most body mounts requirement. If all else is not doing the job buy some liquid urethane rubber and cast your own or cut from rubber truck mud flap. Anchor motor mounts used to have a paper catalog that showed mounts in actual size but probably all is online now. Our latest go to mount is the S10 body mounts. Has a limiter tube in center and cups to limit squish. Thick so not suitable for mounting on top frame flange but great for AD cab mounting as it gets rid of shackle type or center plate mounting and can be shimmed for door alignment.
Evan
| | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Many thanks guys. Thought I would have to improvise and invent. I use the term task force trucks because years ago when I got the truck it came with a couple of photos, a brief history and the previous owner used the term government or task force truck. His notes said GM had a separate assembly line for the military, forestry service and fire departments. Apparently a farmer bought the truck at military auction in 1966, hand painted it yellow and painted a basket with fruits and vegetables on the doors. Unfortunately shortly later the farmer died and his widow put the truck in the barn. 30 odd years later the farm was sold and the vehicle was found. It ended up with the guy I bought it from 16 years ago in Canada. I stopped posting back in 2010. I will put up some newer photos of the project. Thanks again for having good ideas and sharing🙠| | |
