3 members (Stovebolt48, NJC, baldeagle), 71 guests, and 7 robots.
Topics128,018
Posts1,055,342
Members48,419
#1418263 07/26/2021 11:41 PM
OK guys i bought some adapter to put semi wheels on my 67\ c-50. They fit great but i need a source for acorn lug nuts that will fit my truck they are 11/16 studs. The supplies is out of them and cant get any because of covid. I was wondering if anyone knew of a place to get them. Thanks
wickedinhere #1418283 07/27/2021 1:25 AM
Are you running Motor or Budd wheels? RH thread and LH thread or all RH?
Motor wheels use Flanged nuts like these with plastic chrome covers snapped on to make them look pretty.
https://www.summitracing.com/parts/rnb-611-043
Give us the part number of what's "out of stock" so we know what you're looking for...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
wickedinhere #1418291 07/27/2021 2:19 AM
I need 11/16 -16 acorn lug nuts they bolt the adapter to my hub then I bolt my semi wheels to the adapter.
wickedinhere #1418296 07/27/2021 3:07 AM
3B Offline
Hy wickedinhere, "A" you didn't answer Mike's questions. "B" what is wrong with using your original wheel nuts?
wickedinhere #1418302 07/27/2021 4:12 AM
Are the adapters made of aluminum or steel? If they're aluminum, you might be headed for trouble. Those things are built for show trucks, not for doing "real truck" stuff like hauling cargo.
wickedinhere #1418309 07/27/2021 11:29 AM
Ok the original nuts wont fit in the hole on the adapter. Yes they are aluminum and i wont be hauling much if anything just gonna hit cruise nights and ride around and look pretty.
wickedinhere #1418327 07/27/2021 2:47 PM
Sounds a bit like that rolling circus sideshow we saw at Lebanon Tennessee a couple of weeks ago! Most of those things were just plain grotesque! Any machinist with a few brain cells to rub together can make custom nuts to any specification you give him.
wickedinhere #1418396 07/27/2021 8:25 PM
This is what I think of when you say "acorn nut"...
https://www.mcmaster.com/acorn-nuts/
Are you sure your existing lug studs aren't 3/4-16 thread for the Budd stud piloted wheels?
This is what Budd wheel lug nuts look like...
https://www.amazon.com/Outer-Standard-Hand-Thrd-37888/dp/B0040CTY92
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Hotrod Lincoln #1418439 07/28/2021 1:32 AM
Yeah it is and i am the clown paying for the big top. Sorry it doesnt meet your standards but its not like people havent done it before. I will probably just have the original lugs milled a bit to fit the adapter hole. Thanks for all Help
wickedinhere #1418451 07/28/2021 2:53 AM
Bond Villain
Bond Villain
Jerry ... nono "Rolling circus sideshow" pretty much describes any ODSS adventure ...
3B -- should we also discuss which Budd wheel inner nut to use when mixing steel and aluminum wheels/adapters???
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
wickedinhere #1418458 07/28/2021 3:17 AM
John, you really had to be there- - - -1/2 ton pickups from the mid-1980's with the rocker panels about 3 inches off the ground, running polished billet aluminum 10-lug Budd 24 inch wheels with pointy lug nut covers 6 inches long! And somebody did that on purpose???????
wickedinhere #1418479 07/28/2021 9:38 AM
Bond Villain
Bond Villain
Sounds like a par-TAY!!! Fer Shur had to be there! .... With Mike Roache, 2-Ton and Kiwi Tim .... festooned with chrome beanies and flashing LED mardi-gras beads, leading a conga line of chrome shop catalog shoppers through your hotel room at 0230 with a Jamaican steel band .... dance
Woo hoo, I'm jazzed just imagining it!!
Ahem ... where were we? Ah ... Ok, not your cup of tea, then. But They are having fun with their trucks their way -- isn't that what this is all about? We can at least join them in the joy of this hobby even if it might not be something that we would do ourselves, ja? Weep with those who weep but rejoice with those who rejoice. No weeping here. wave
Besides, the OP wants to put those Alcoas on a C-50, not a slammed pickup. I'm thinking that will look pretty sharp.
It's not like he's putting those 10-lug 24-in polished Alcoas on a '78 Caprice ... eeeek
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Hotrod Lincoln #1418486 07/28/2021 12:32 PM
I bet you drive one of those squatted trucks.
John Milliman #1418487 07/28/2021 12:34 PM
Thanks yes people have done it before and it looks way better than the original wheels i am doing a super single in the rear. The tires it had on it when i got it are all dry rotten.
wickedinhere #1418618 07/29/2021 1:02 PM
Bond Villain
Bond Villain
That's right. people have done it before -- lots of people. And those wheels should look right at home on your truck. I like the idea of the super singles. THAT you don't see so much yet. I won't be putting them on *my* truck anytime soon but I will enjoy the pictures of your truck when you get this altogether smile
And about Hotrod Lincoln ... stick around here and you'll find, as many of us have, that he is very generous with his knowledge, experience, skill, capability and ... opinions wink All of which he has in copious amounts. He'd be the first one to your house with his van full of parts, tools and whatever else to help you with a problem. Look past this minor difference of aesthetic opinion and you will find a true friend with gobs of knowledge. Besides, you're both Southerners. Imagine what *I* have to go through with him being not just a Yankee, but a darn Yankee (Born and bred Northern New Englander now living south of the Mason-Dixon line) ...
To fully understand what I am talking about, you *HAVE* to read this -- this is what happens when you simply invite Jerry to ride in your truck. He hears a strange noise (that none of the rest of us do) ... and , well, the Tech Tip happened after that....
The truly great thing about Jerry is that we *never* have to wonder what his opinion is or what he's thinking .... smile Today, you are on the opposite side. Welcome to the club!! There's a lot of us in here!
[elvis]
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
wickedinhere #1418629 07/29/2021 2:22 PM
Thanks for the support, John! Those guys with webs between their toes from wading in the swamps all their lives call ME a yankee! They talk funny, too- - - -"I guar-on-tee it!"
LOL!
wickedinhere #1418716 07/30/2021 2:28 AM
So, did you ever figure out what type of nut you're looking for?
Lug piloted Budd nuts for the adaptors and Motor Wheel flanged nuts for the hub piloted Alcoa's?
Left or Right thread?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
wickedinhere #1418751 07/30/2021 3:22 PM
Mike cant seem to find what i am looking for so i am just gonna have the stock nuts milled down to what i need.
wickedinhere #1418761 07/30/2021 4:24 PM
It's hard to help when we don't really know what you're looking for...post some pictures of what you have and what you need.
Is the adaptor made to go from Stud Piloted (original hub/wheels) to Hub Piloted or Stud Piloted Alcoa's?
The adaptor should be made to except your original lug nuts for holding it to the hub. Then you'll use the correct size nuts to hold the Alcoa's to the adaptor. Contact the company that made the adaptor to confirm you have the right parts...I would NOT machine a nut to fit, that would remove it's strength and holding capacity.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
wickedinhere #1418777 07/30/2021 6:13 PM
I will post pic of adapter later
wickedinhere #1418864 07/31/2021 1:05 PM
OK so i said i need acorn nuts but i need nuts just like the stock one from my truck but just slightly small. The flange on the nut is just a tad to big so unless i can get a nut like in the pic with a total diameter of 1-1/8 i will either have to mill the adapter holes slightly larger or the nuts smaller. I will probably do the adapter but the machinest will make that decision. Pics included are the stock truck nuts 11/16-16 my adapters and my super single wheels.klh
wickedinhere #1418866 07/31/2021 1:27 PM
The adapters are piloted to piloted wheels flange nuts
wickedinhere #1418897 07/31/2021 6:59 PM
Those are "Hub Piloted" to "Hub Piloted" adaptors...
If it were me I'd call the adaptor vendor and get the adaptors machined to fit the stock 1-1/8" wide flange nut or have them provide the correct nuts. Are the holes drilled for 11/16" studs?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
wickedinhere #1418906 07/31/2021 7:55 PM
They dont sell the lug nuts yes the holes are drilled for the 11/16 stud.
wickedinhere #1418934 08/01/2021 12:28 AM
Do they advertise this adaptor is for your truck, or are you just making it fit?
All 11/16" flanged lug nuts that I've found are 1-1/8" wide...what nuts do they recommend to fit their hole even if they don't sell them?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
wickedinhere #1418978 08/01/2021 11:22 AM
Yes they say it will work for my truck. I called them and they are pretty clueless on the lug nuts. They probably havent sold many, I will get it done for sure I will post when i get a final solution.
wickedinhere #1419124 08/02/2021 5:00 AM
I haven't read everything but by looking at the pictures it looks like he has a 14x22.5 wheel and an adapter to put it on something with 10 lugs. I would assume he wants to put 445/50R22.5 tires on whatever he is building. He doesn't need acorn nuts. He needs 33mm lug nuts if that is the case. That is the standard of the industry these days. I have buckets full of them laying around. They can be bought at any truck dealer. Even Amazon has them.
https://www.amazon.com/20-Pack-33-Wheel-Nuts/dp/B01G606AGK
If he wants acorns on them, they can be bought at any chrome shop. I have lots of them around. I make the drivers remove them because it is hard to tell of the lug nut is coming loose. And I want my drivers to look professional, not like kids that just fell out of truck driving school. This may be what he is referring to as acorn nuts.
https://zips.com/parts-detail/unite...F-SY7W7bvBmSzfhactVcbx0OJyhoCe-4QAvD_BwE
As far as the adapters being aluminum, if they are quality made there is nothing wrong with them.
Conmet aluminum hubs have logged millions on top of million miles.
https://conmet.com/oem/conmet-proprietary-products/hub-assemblies/
wickedinhere #1419194 08/03/2021 12:06 AM
Yes 33mm for the 22.5 wheels. The truck takes 11/16-16 that bolt the adapter to the hub and then 33mm nuts to bolt the semi wheels to the adapter. I brought the adapters and lug nuts to the machinest today and he said there is enough meat on the nuts to mill down to fit the adapters. So we are good on that for now. Thanks
wickedinhere #1419218 08/03/2021 4:30 AM
I think I now get the picture of what you are trying to do. But I'm still confused what your are having machined. An 11/16-16 flange nut is a common lug bolt. It is Dorman 611-043. Is it that the flange won't fit in the hole of the adapter. If that is the case cutting a little off of the flange won't hurt anything. You will be removing the 33 mm flange nuts if you remove the wheels so you can put Loctite on the threads of the 11/16-16 nuts. Google Dorman 611-043 and you will find quite a few vendors who have them on hand. Did you buy the adapters as a stock item or were they custom made. I run 445/50R225 but I don't know that I would care for them on a bob tail. However these things would work for duals as well as singles.
wickedinhere #1419238 08/03/2021 1:48 PM
I am machining a little off the 11/16 lug nuts so they fit in the hole on the adapter. I ordered the 33mm lug nuts which require no machining.LOL This is my first time with these trucks adapters and semi wheels so its a learning experience.
wickedinhere #1419306 08/03/2021 9:08 PM
It's hard to believe the maker of the adaptor didn't research the diameter of the 11/16-16 Flange nut to make sure they machined the hole to fit the nut...poor quality control on their part.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
wickedinhere #1419342 08/04/2021 1:29 AM
It is what it is! They at least milled the holes big enough for the 1-1/8 socket to fit. There may be a lugnut that does fit the hole and if so its probably a special order and hard to get
wickedinhere #1420039 08/10/2021 1:21 AM
I got my nuts back today.LOL Perfect fit [img]https://imagizer.imageshack.com/img922/999/D91AvF.jpg[/img]
wickedinhere #1421092 08/18/2021 11:22 PM
Well got one side done will move to the other side and fix the brakes then be on the road soon.[img]https://imagizer.imageshack.com/img924/7651/BNyFTY.jpg[/img]
wickedinhere #1421108 08/19/2021 3:13 AM
I'm normally not a fan of the kind of modifications you are doing, but this one actually looks really good. I see it has a 5th wheel. Does it have air brakes or is it air over hydraulic.
wickedinhere #1421121 08/19/2021 10:33 AM
Thanks its drum brakes all the way around.
wickedinhere #1421139 08/19/2021 2:20 PM
Looks good!
Air Brakes or Hydraulic Brakes ???
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
wickedinhere #1421164 08/19/2021 5:39 PM
Hydraulic Brakes
wickedinhere #1421323 08/21/2021 12:37 AM
There is a '62 2-ton in a local junkyard that I just took the rear wheels off of. I can go grab the lugs out of the dirt if you want them, but they're kind of cruddy.
wickedinhere #1421927 08/26/2021 3:12 AM
I got mine milled to fit but Thanks
