2 members (KEVINSKI, JW51),
79
Mod | | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | OK guys i bought some adapter to put semi wheels on my 67\ c-50. They fit great but i need a source for acorn lug nuts that will fit my truck they are 11/16 studs. The supplies is out of them and cant get any because of covid. I was wondering if anyone knew of a place to get them. Thanks | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Are you running Motor or Budd wheels? RH thread and LH thread or all RH? Motor wheels use Flanged nuts like these with plastic chrome covers snapped on to make them look pretty. https://www.summitracing.com/parts/rnb-611-043Give us the part number of what's "out of stock" so we know what you're looking for... Mike B  | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | I need 11/16 -16 acorn lug nuts they bolt the adapter to my hub then I bolt my semi wheels to the adapter. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy wickedinhere, "A" you didn't answer Mike's questions. "B" what is wrong with using your original wheel nuts? | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Are the adapters made of aluminum or steel? If they're aluminum, you might be headed for trouble. Those things are built for show trucks, not for doing "real truck" stuff like hauling cargo. Jerry
| | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | Ok the original nuts wont fit in the hole on the adapter. Yes they are aluminum and i wont be hauling much if anything just gonna hit cruise nights and ride around and look pretty. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Sounds a bit like that rolling circus sideshow we saw at Lebanon Tennessee a couple of weeks ago! Most of those things were just plain grotesque! Any machinist with a few brain cells to rub together can make custom nuts to any specification you give him. Jerry
| | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | Sounds a bit like that rolling circus sideshow we saw at Lebanon Tennessee a couple of weeks ago! Most of those things were just plain grotesque! Any machinist with a few brain cells to rub together can make custom nuts to any specification you give him. Jerry Yeah it is and i am the clown paying for the big top. Sorry it doesnt meet your standards but its not like people havent done it before. I will probably just have the original lugs milled a bit to fit the adapter hole. Thanks for all Help | | | | | Joined: Nov 1995 Posts: 5,714 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,714 | Jerry ...  "Rolling circus sideshow" pretty much describes any ODSS adventure ... 3B -- should we also discuss which Budd wheel inner nut to use when mixing steel and aluminum wheels/adapters???
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | John, you really had to be there- - - -1/2 ton pickups from the mid-1980's with the rocker panels about 3 inches off the ground, running polished billet aluminum 10-lug Budd 24 inch wheels with pointy lug nut covers 6 inches long! And somebody did that on purpose???????
| | | | | Joined: Nov 1995 Posts: 5,714 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,714 | Sounds like a par-TAY!!! Fer Shur had to be there! .... With Mike Roache, 2-Ton and Kiwi Tim .... festooned with chrome beanies and flashing LED mardi-gras beads, leading a conga line of chrome shop catalog shoppers through your hotel room at 0230 with a Jamaican steel band .... Woo hoo, I'm jazzed just imagining it!! Ahem ... where were we? Ah ... Ok, not your cup of tea, then. But They are having fun with their trucks their way -- isn't that what this is all about? We can at least join them in the joy of this hobby even if it might not be something that we would do ourselves, ja? Weep with those who weep but rejoice with those who rejoice. No weeping here.  Besides, the OP wants to put those Alcoas on a C-50, not a slammed pickup. I'm thinking that will look pretty sharp. It's not like he's putting those 10-lug 24-in polished Alcoas on a '78 Caprice ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | John, you really had to be there- - - -1/2 ton pickups from the mid-1980's with the rocker panels about 3 inches off the ground, running polished billet aluminum 10-lug Budd 24 inch wheels with pointy lug nut covers 6 inches long! And somebody did that on purpose??????? I bet you drive one of those squatted trucks. | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | Sounds like a par-TAY!!! Fer Shur had to be there! .... With Mike Roache, 2-Ton and Kiwi Tim .... festooned with chrome beanies and flashing LED mardi-gras beads, leading a conga line of chrome shop catalog shoppers through your hotel room at 0230 with a Jamaican steel band .... Woo hoo, I'm jazzed just imagining it!! Ahem ... where were we? Ah ... Ok, not your cup of tea, then. But They are having fun with their trucks their way -- isn't that what this is all about? We can at least join them in the joy of this hobby even if it might not be something that we would do ourselves, ja? Weep with those who weep but rejoice with those who rejoice. No weeping here.  Besides, the OP wants to put those Alcoas on a C-50, not a slammed pickup. I'm thinking that will look pretty sharp. It's not like he's putting those 10-lug 24-in polished Alcoas on a '78 Caprice ...  Thanks yes people have done it before and it looks way better than the original wheels i am doing a super single in the rear. The tires it had on it when i got it are all dry rotten. | | | | | Joined: Nov 1995 Posts: 5,714 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,714 | That's right. people have done it before -- lots of people. And those wheels should look right at home on your truck. I like the idea of the super singles. THAT you don't see so much yet. I won't be putting them on *my* truck anytime soon but I will enjoy the pictures of your truck when you get this altogether  And about Hotrod Lincoln ... stick around here and you'll find, as many of us have, that he is very generous with his knowledge, experience, skill, capability and ... opinions  All of which he has in copious amounts. He'd be the first one to your house with his van full of parts, tools and whatever else to help you with a problem. Look past this minor difference of aesthetic opinion and you will find a true friend with gobs of knowledge. Besides, you're both Southerners. Imagine what *I* have to go through with him being not just a Yankee, but a darn Yankee (Born and bred Northern New Englander now living south of the Mason-Dixon line) ... To fully understand what I am talking about, you *HAVE* to read this -- this is what happens when you simply invite Jerry to ride in your truck. He hears a strange noise (that none of the rest of us do) ... and , well, the Tech Tip happened after that.... The truly great thing about Jerry is that we *never* have to wonder what his opinion is or what he's thinking ....  Today, you are on the opposite side. Welcome to the club!! There's a lot of us in here! ![[elvis] [elvis]](/ubbthreads/images/graemlins/default/elvis.gif)
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Thanks for the support, John! Those guys with webs between their toes from wading in the swamps all their lives call ME a yankee! They talk funny, too- - - -"I guar-on-tee it!" LOL! Jerry
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | So, did you ever figure out what type of nut you're looking for? Lug piloted Budd nuts for the adaptors and Motor Wheel flanged nuts for the hub piloted Alcoa's? Left or Right thread? Mike B  | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | Mike cant seem to find what i am looking for so i am just gonna have the stock nuts milled down to what i need. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Mike cant seem to find what i am looking for so i am just gonna have the stock nuts milled down to what i need. It's hard to help when we don't really know what you're looking for...post some pictures of what you have and what you need. Is the adaptor made to go from Stud Piloted (original hub/wheels) to Hub Piloted or Stud Piloted Alcoa's? The adaptor should be made to except your original lug nuts for holding it to the hub. Then you'll use the correct size nuts to hold the Alcoa's to the adaptor. Contact the company that made the adaptor to confirm you have the right parts...I would NOT machine a nut to fit, that would remove it's strength and holding capacity. Mike B  | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | I will post pic of adapter later | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | OK so i said i need acorn nuts but i need nuts just like the stock one from my truck but just slightly small. The flange on the nut is just a tad to big so unless i can get a nut like in the pic with a total diameter of 1-1/8 i will either have to mill the adapter holes slightly larger or the nuts smaller. I will probably do the adapter but the machinest will make that decision. Pics included are the stock truck nuts 11/16-16 my adapters and my super single wheels. klh | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | The adapters are piloted to piloted wheels flange nuts
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | The adapters are piloted to piloted wheels flange nuts Those are "Hub Piloted" to "Hub Piloted" adaptors... If it were me I'd call the adaptor vendor and get the adaptors machined to fit the stock 1-1/8" wide flange nut or have them provide the correct nuts. Are the holes drilled for 11/16" studs? Mike B  | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | They dont sell the lug nuts yes the holes are drilled for the 11/16 stud. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Do they advertise this adaptor is for your truck, or are you just making it fit? All 11/16" flanged lug nuts that I've found are 1-1/8" wide...what nuts do they recommend to fit their hole even if they don't sell them? Mike B  | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | Yes they say it will work for my truck. I called them and they are pretty clueless on the lug nuts. They probably havent sold many, I will get it done for sure I will post when i get a final solution. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I haven't read everything but by looking at the pictures it looks like he has a 14x22.5 wheel and an adapter to put it on something with 10 lugs. I would assume he wants to put 445/50R22.5 tires on whatever he is building. He doesn't need acorn nuts. He needs 33mm lug nuts if that is the case. That is the standard of the industry these days. I have buckets full of them laying around. They can be bought at any truck dealer. Even Amazon has them. https://www.amazon.com/20-Pack-33-Wheel-Nuts/dp/B01G606AGKIf he wants acorns on them, they can be bought at any chrome shop. I have lots of them around. I make the drivers remove them because it is hard to tell of the lug nut is coming loose. And I want my drivers to look professional, not like kids that just fell out of truck driving school. This may be what he is referring to as acorn nuts. https://zips.com/parts-detail/unite...F-SY7W7bvBmSzfhactVcbx0OJyhoCe-4QAvD_BwEAs far as the adapters being aluminum, if they are quality made there is nothing wrong with them. Conmet aluminum hubs have logged millions on top of million miles. https://conmet.com/oem/conmet-proprietary-products/hub-assemblies/ | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | Yes 33mm for the 22.5 wheels. The truck takes 11/16-16 that bolt the adapter to the hub and then 33mm nuts to bolt the semi wheels to the adapter. I brought the adapters and lug nuts to the machinest today and he said there is enough meat on the nuts to mill down to fit the adapters. So we are good on that for now. Thanks | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think I now get the picture of what you are trying to do. But I'm still confused what your are having machined. An 11/16-16 flange nut is a common lug bolt. It is Dorman 611-043. Is it that the flange won't fit in the hole of the adapter. If that is the case cutting a little off of the flange won't hurt anything. You will be removing the 33 mm flange nuts if you remove the wheels so you can put Loctite on the threads of the 11/16-16 nuts. Google Dorman 611-043 and you will find quite a few vendors who have them on hand. Did you buy the adapters as a stock item or were they custom made. I run 445/50R225 but I don't know that I would care for them on a bob tail. However these things would work for duals as well as singles. | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | I am machining a little off the 11/16 lug nuts so they fit in the hole on the adapter. I ordered the 33mm lug nuts which require no machining.LOL This is my first time with these trucks adapters and semi wheels so its a learning experience. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | It's hard to believe the maker of the adaptor didn't research the diameter of the 11/16-16 Flange nut to make sure they machined the hole to fit the nut...poor quality control on their part. Mike B  | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | It is what it is! They at least milled the holes big enough for the 1-1/8 socket to fit. There may be a lugnut that does fit the hole and if so its probably a special order and hard to get | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I'm normally not a fan of the kind of modifications you are doing, but this one actually looks really good. I see it has a 5th wheel. Does it have air brakes or is it air over hydraulic. | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | Thanks its drum brakes all the way around. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Looks good! Air Brakes or Hydraulic Brakes ??? Mike B  | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | | | | | | Joined: Jun 2021 Posts: 58 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 58 | There is a '62 2-ton in a local junkyard that I just took the rear wheels off of. I can go grab the lugs out of the dirt if you want them, but they're kind of cruddy. | | | | | Joined: Jun 2021 Posts: 61 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 61 | I got mine milled to fit but Thanks | | |
