5 members (klhansen, Otto Skorzeny, Cosmo, Bwana-Jim, J Lucas), 95 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
Hello,
Not sure where to ask this Q?
How do I tell a one ton chassis from a one and 1/2 ton chassis?
Assuming I'm looking at a rolling chassis, no sheet metal, model numbers, etc.
Seller says it's a one ton, no reason to doubt, except I want to try to be sure.
I know to measure wheel base first. If it's 137, then what next, 8 vs. 11 leaf springs?
Thanks for any help anyone can offer. Mike.
back yard wrench turner
Originally Posted by MikeStone1953
Hello,
Mike 1st we need to know what year you are asking about.
The spec manuals are here, look up the year of the truck you are asking about.
http://chevy.oldcarmanualproject.com/index.htm
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
This site is a little easier to find the info in.
It has info on wheelbase, springs, etc.
Crusing in the Passing Lane
Do you know if Chevy or GMC? ‘41-‘47 GMC one ton would have 6 on 7.25” wheels, GMC engine. 1.5ton would have 20” wheels. All GMC engines are different from Chevy if present.
Ed
3/4 and 1 ton GMC's would have the rear axle under the rear leaf spring, the 1/2 ton would have the axle on top of the rear leaf spring. The 3/4 and 1 ton GMC rear frame is narrower than the 1/2 ton GMC. Over all frame would be longer on the 3/4 and 1 ton GMC's unless the 1/2 ton was ordered with a longer bed. Regardless the 3/4 and 1 ton GMC's frames are narrower than the 1/2 tons. 3/4 ton GMC's have 16" wheels in 1946, Chevy 15" in 1946, both 8 hole.
1946 with WWII 270
Hi,
I asked about the year, and gmc vs chevy, and he wasn't sure. He said he would check and might have the info, but I wouldn't bet on it.
I think the wheels and engine are gone, and he won't have info on either. He assured me it was indeed an advanced design model, one ton,
1950 to 1953. This is a bare chassis. He said the front was intact, and the axles were off in the rear. Probably all I have to work with other
than seeing it, and measuring what ever I can. Thanks for the responses! It's 100 miles away, but that seems to be as close as I can find!
Here's where a picture would really help... pix
1-ton will be 8 lug F & R...
1-1/2 ton will be 10 lug rear/5 lug front
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
