1 members (Leo), 104 guests, and 1 robot.
Topics128,049
Posts1,055,743
The front brake drum needs to be replaced. Also, two wheel studs need replacing. I pounded on one of the studs for an hour and it budged a little.
What is the best way to replace the drum and studs? Thanks.
First, cut, grind or torch the heads off the rivets that hold the drum to the hub. Then use a swage-cutting tool in a low speed drill press to remove the expanded portion of the studs that also attach the drum to the hub. Then hammer or press the studs out.
Crusing in the Passing Lane
Make sure the hub/drum is backed up when hammering on it, otherwise it will just bounce.
Ed
What would happen if I re-assemble this and ignore the rivets? It seems to the studs should hold the assembly together fine.
The hub is scarred a little from removing the stud. Is this anything to worry about?
I don't think anyone worries about replacing those rivets.
1951 1 Ton Completed
Riding in the Passing Lane
I always leave the end of the old rivet in the hole. It is expanded in the hole & won't fall out. As long as there is no metal that will keep the drum from surfacing on the flange you are all right. If there is grind it down.
George
1972 Chevy c10 Cheyenne Super
