8 members (2-Ton, homer52, Tiny, Hotrod Lincoln, mo2cyl, Woodcmiami, 66flea, 1 invisible), 107 guests, and 3 robots.
Topics128,049
Posts1,055,662
57 Chevy 3800 235ci 4 spd trans during drill test of cable speedometer and odometer works as it should but not when connected to trans. Where do I check next?
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Trans I’d J1058 I thinks is sm420 so now I’m looking for a speedometer gear
More pix on Flickr
Camp Commandant
Camp Commandant
Duwop, in the drill test was the drill hooked up to the trans end of the speedo cable? Probably a stupid question but just trying to rule the cable itself out as the culprit.
~ Billy
1959 GMC 860 | Pictures
Crusing in the Passing Lane
Cable might just be too short when installed.
Ed
Yes drill hooked to trans end of cable, sorry about the delay in response as I’ve been researching more info. The following is what I’ve come up with
I’ve got sm420 trans but not sure about date codes matching my 57 truck(see pic)
I’ve got a 13 tooth speedometer drive gear my rear axle ratio should be 5.14:1 as per specs in manual any information you can provide would be of help
More pix on Flickr
I would disconnect the cable from the speedo and see if it spins while driving.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Thanks Walter, can’t hurt to give it a try
More pix on Flickr
I spent days when I was younger trying to find the same problem. The replacement inner cable was to short. Finally bought the cable and casing, success! Doc
Doc.Hall, so I looked at the cable after your post and it appeared that the cable connection at the speedometer was broke and possibly short. I ordered a new cable and installed it and went for a drive to put some gas in it to test the new fuel gauge and sending unit. The speedometer is working though it’s about 3-5 mph behind gps.
So for now that is close enough for me. Thank you very much for your suggestions
More pix on Flickr
Moderated by  Dusty53
