6 members (Woodcmiami, Gdads51, cmayna, mick53, MickeyP, 1 invisible), 42 guests, and 9 robots.
Topics128,012
Posts1,055,312
Members48,419
#14193 11/27/2003 7:10 AM
Junior Member
Junior Member
Just picked up a '58 1/2 ton with a non-original V-8. Different from previous '58 283 I've seen such as oil dipstick on the right instead of the left. also some more modern emission equipment. I looked up some engine I.D. numbers on the Americanclassic.com site mentioned in previous postings. The stampings on the front right side of the block are large figures -VO712TCK and small print 1CF720419. The only thing I can match up are the CF for some years about 1960 and that indicates a 283. Does anyone know if that's correct and what all the other numbers and letters mean?
#14194 11/27/2003 7:52 AM
Quote
Originally posted by apachebob:
some more modern emission equipment?
1968 was the last year for 283s. Maybe it was different in California in '68, but I don't think there was much in the way of emission equipment in '68 was there?
PCV insead of vent tube. I wouldn't expect anything else. The air pumps and filter boxes and all those hoses started a few years later.
I don't have a resource for checking numbers, but I'm wondering if its not a 283?
#14195 11/27/2003 8:16 AM
oldsub - 67 was actually last year of 283
bob - I know that the dipstick was on the 'wrong' side on some bigger trucks, and most later pollution stuff will fit right onto an earlier engine - look for casting number at rear of drivers side just in front of bellhousing - can usually read it w/ a piece of mirror if the blocks not toooo dirty - will tell if it's a 283 or what
#14196 11/29/2003 1:20 AM
Junior Member
Junior Member
I'll take a look at the rear drivers side of the block. they stamped a lot of stuff on the front passenger side. I also thought it was strange how small the spark plugs are. I need to buy a 5/8" plug wrench to get them out so I can start analyzing this motor.
#14197 11/29/2003 3:14 AM
The V0712TCK number in my information says.
V=Flint plant
0712= July 12th
TCK= 1973 307 cu in. from C-20 to 3500 series truck
Hope this helps.
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
#14198 11/29/2003 6:13 AM
The second part of the numbers was the last part of the original vehicle's VIN.
Steve Ley
51 Chevrolet Canopy Express
02 K25 Duramax Crew Cab
#14199 11/30/2003 2:52 AM
Quote
Oops... I was thinking '68 was the first year for the 350, and confused myself... I wish it was only the first time that happened!
#14200 12/02/2003 12:36 AM
Junior Member
Junior Member
thankyou guys and 38 spshl. That sounds like a pretty good I.D. Now I'll try to figure out why it's smoking and see if it's a keeper or rebuilder?
