| | | Forums66 Topics128,089 Posts1,056,005 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 15 'Bolter | | 'Bolter Joined: May 2015 Posts: 15 | Hi knowers, my 350ci engine in my 1949 Chevy will only start in the moment when i release the start knob. The truck is swap to V8 and 12volt 8 years ago and starts all time before verry good. When i push the start knob the starter turns the engine normaly but it will only start in the moment of release, it didnt start all time in this moment of course. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ray2, what type of distributor are you using, a point type one or an H.E.I. one? What type of starter motor activation switch are you using, a key switch which activates the starter when the key is turned all the way to the right, or a push button switch which activates the starter when pushed? If you are using a point type distributor your resistor bypass circuit may be open or damaged.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Normally when a person hears the motor fire, they release the button and starter stops turning and motor keeps running. I think you are saying that the motor does not fire at all until button is released. Is that correct? This means you do not have the starter wired properly.
Does the starter solenoid have a big stud for the battery cable and two other smaller terminals?
Are these terminals labeled "B" (BATT) "S" (SOL) "R"
Answer knower 3B questions also.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I have seen a similar issue on fuel injection conversions where the ignition part are connected to a "hot in run" circuit rather than a "hot in run and start" circuit.
You might verify that more than just your starter is getting power when you are pressing the start button. | | | | | Joined: Dec 2020 Posts: 1,961 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,961 | Normally when a person hears the motor fire, they release the button and starter stops turning and motor keeps running. I think you are saying that the motor does not fire at all until button is released. Is that correct? This means you do not have the starter wired properly.
Answer knower 3B questions also. This.....
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: May 2015 Posts: 15 'Bolter | | 'Bolter Joined: May 2015 Posts: 15 | I use a pointer distributor and a push button switch with the original key lock. I will check the resistor bypass circuit. | | | | | Joined: May 2015 Posts: 15 'Bolter | | 'Bolter Joined: May 2015 Posts: 15 | Hi bartamos, Thats correct, i use the original wiring and will check the starter wiring. | | |
