3 members (Gdads51, Ponchogl, mick53), 39 guests, and 2 robots.
Topics128,090
Posts1,056,018
Members48,430
Hi knowers,
my 350ci engine in my 1949 Chevy will only start in the moment when i release the start knob.
The truck is swap to V8 and 12volt 8 years ago and starts all time before verry good.
When i push the start knob the starter turns the engine normaly but it will only start in the moment of release,
it didnt start all time in this moment of course.
3B Offline
Hy Ray2, what type of distributor are you using, a point type one or an H.E.I. one? What type of starter motor activation switch are you using, a key switch which activates the starter when the key is turned all the way to the right, or a push button switch which activates the starter when pushed? If you are using a point type distributor your resistor bypass circuit may be open or damaged.
Sir Searchalot
Sir Searchalot
Normally when a person hears the motor fire, they release the button and starter stops turning and motor keeps running. I think you are saying that the motor does not fire at all until button is released. Is that correct?
This means you do not have the starter wired properly.
Does the starter solenoid have a big stud for the battery cable and two other smaller terminals?
Are these terminals labeled "B" (BATT) "S" (SOL) "R"
Answer knower 3B questions also.
I have seen a similar issue on fuel injection conversions where the ignition part are connected to a "hot in run" circuit rather than a "hot in run and start" circuit.
You might verify that more than just your starter is getting power when you are pressing the start button.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
This.....
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I use a pointer distributor and a push button switch with the original key lock.
I will check the resistor bypass circuit.
Hi bartamos,
Thats correct, i use the original wiring and will check the starter wiring.
