4 members (Otto Skorzeny, tclederman, Lostbuthaulinass, 1 invisible), 81 guests, and 4 robots.
Topics128,142
Posts1,056,478
Members48,441
#1419051 08/01/2021 7:09 PM
Is there any binifit to having 6 lug lug or 5 lugs? I know it’s best to have same front and rear but is it any benefits in one or the other?
Csims #1419053 08/01/2021 7:21 PM
Not having to carry 2 spares.
Csims #1419055 08/01/2021 7:51 PM
Larger variety of sizes and wheel designs available with the 5 lug configuration in both stock and aftermarket wheels.
Fred
Csims #1419078 08/01/2021 10:06 PM
Thanks for the replies. I will in the future be putting a m11 front suspension. I am looking for a rear end and wanted to get them to match as far as the lugs.
Csims #1419221 08/03/2021 4:46 AM
Yeah, I am looking at the same idea. The MII front end from Tuckers has a 5x4.75 pattern, the same as the 2000s 4WD S10 axle that is the correct width. That combo gives power steering, 4 wheel disks, and a posi rear end (if you get a G80) for a pretty good deal.
I have the 5" wide rims now and want to go wider so I have more tire options. The 5-lug pattern is more common, so the aftermarket has many more choices. It doesn't hurt that I am partial to 5 spoke rims. My first car had torq-thrust 2s and I have been stuck with an enduring love for them ever since.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Csims #1419224 08/03/2021 5:59 AM
Fox Offline
Have you considered a narrowed Ferd Explorer 8.8 rear end? Piles of those in wreckers. I got a 97 rear with posi, complete with good pads, an extra passenger axle (in order to narrow the rear), and cables for $120 at my wrecker. 5x4.5” bolt pattern.
If you are a decent enough welder or have a capable buddy, narrowing one of these rears is a very good option. I did this in my wife’s 62 Rambler American. 56.5” WMS TO WMS if you’re curious.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
