5 members (Hotrod Lincoln, Steelonsteel, kbenz, Otto Skorzeny, BC59), 125 guests, and 3 robots.
Topics128,087
Posts1,056,372
Members48,442
I have a 1982 c-10, with a 250 engine. The engine is in the truck. What firing position would the engine be in to make removal of the oil pan easier? I realize that I will have to jack the engine off of the mounts, I seem to remember reading somewhere if the engine was firing on a certain cylinder it would be easier to remove the oil pan. Any thoughts?
Thank You.
Tommy
59 apache 1/2t
261 short stepside
It shouldn't matter, but if you want, put the front pistons mid-way up the bores. The front of the pan is the shallowest, so that is where you would need extra clearance.
Thanks Joe.
Tommy
59 apache 1/2t
261 short stepside
Riding in the Passing Lane
Its the counter weight that can be in the way. When you drop the pan down a ways you can see the CW. Turn the engine enough so the CW is up.
George
1972 Chevy c10 Cheyenne Super
