| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 62 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 62 | how best to replace the rubber boot under the foot starter---thanks
1948 3/4 ton Chevy Pickup
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Don’t know the year your referring to but I’ll tell you on mine it was straight up easy. Remove round piece that your foot would press, slip boot down over shaft attach boot around floor board reinstall round piece to shaft | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | To expand a bit on what Duwop has posted; The round piece or button that your foot would press is screwed on. On the backside of the button is a 3/4 hex, so get a 3/4 wrench or crescent wrench and unscrew the button. Then just slip the boot down over the shaft. Kent | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | With a little creative fitting, an accordion shaped boot from a rack & pinion steering gear tie rod will last a lot longer than one of those 3rd. world made repop starter pedal boots. Jerry
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | |
