3 members (Gray_Ghost, Steelonsteel, Gdads51), 46 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
how best to replace the rubber boot under the foot starter---thanks
1948 3/4 ton Chevy Pickup
Don’t know the year your referring to but I’ll tell you on mine it was straight up easy.
Remove round piece that your foot would press, slip boot down over shaft attach boot around floor board reinstall round piece to shaft
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
To expand a bit on what Duwop has posted; The round piece or button that your foot would press is screwed on. On the backside of the button is a 3/4 hex, so get a 3/4 wrench or crescent wrench and unscrew the button. Then just slip the boot down over the shaft.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
With a little creative fitting, an accordion shaped boot from a rack & pinion steering gear tie rod will last a lot longer than one of those 3rd. world made repop starter pedal boots.
Fox Offline
Great idea, Jerry.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Moderated by  ndkid275, Phak1
