4 members (Jack Ryan, Craig /49 Panel, Otto Skorzeny, 1 invisible), 73 guests, and 2 robots.
Topics128,083
Posts1,056,326
Members48,442
#1418662 07/29/2021 6:55 PM
Age must be getting to me. 1954 - 3100. I have out these huge rubber grommets on several times in the past. I guess I keep secrets pretty good. I can't remember the easier way to put them on, tried olive oil, 30 weight, grease and a slab of bacon. My hands are very strong and the grommet is new, maybe I should try J&Y jelly. What is the method or secrete? Doc.
Doc.Hall #1418713 07/30/2021 2:14 AM
Is the tank in place? That would make it all but impossible, so I am guessing that is not the case.
Doc.Hall #1418717 07/30/2021 2:48 AM
Insomniac
Insomniac
I managed to work it in. Used a large drift punch to push it in - a screwdriver would be too sharp and would slice through it. Had to go around and around pushing a bit at a time until it was done. Took a while!
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Doc.Hall #1418720 07/30/2021 4:26 AM
Fox Offline
Mine were a bugger to get on with the tank in cab.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Doc.Hall #1418730 07/30/2021 11:09 AM
I used Vaseline on it. Second time I had to do this because the first one I installed "cracked" after 2 years so the replacement was from Steele Rubber Products. The gas tank was installed but the filler neck was not.
Ron - - Dusty53
1954 Chevy 3604
Doc.Hall #1418834 07/31/2021 2:18 AM
Have you tried soap? I remember putting a driveshaft carrier bearing in. Instructions said to use soap as a lube. First tried dish soap(detergent), didn't work at all. Engine oil didn't work. Worked up a thick lather from a bar of bath soap and it went in easily.
Harold Wilson
41 Chevy 3/4 Ton
