| | | Forums66 Topics128,174 Posts1,057,114 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 11 Junior Member | | Junior Member Joined: Oct 2004 Posts: 11 | Seems like I read somewhere that my 1952 2 ton came with a choice of only two, two-speed rear ends. Does anyone know if this is true and what the gear ratios of the choices was/is? I've owned a similar size IHC and they used Eaton rear ends and had numerous choices for their 2-speeds. Thanks for the help. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | According to the reprint of the Chevrolet Truck Shop Manual 1948-50 2-speed axles had 6.13 & 8.10. It doesn't show ratios for '51-up so I would assume nothing changed. 2-tons with 1-speed axle were 6.17. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Only one Two speed rear axle was available in Chevrolet Advance Design Trucks, & that was a Timken 6.13 - 8.10 , GMC's came with several different Eaton 2 spd.'s depending on the series.If you have a Eaton, chances are it's out of another truck. | | | | | Joined: Jun 2006 Posts: 1 Junior Member | | Junior Member Joined: Jun 2006 Posts: 1 | heelo again--you recently answered my parts wanted add for a 48 chev rear axle--i was wondering if you had one or knew of any other make than ran these rearends. also i was wondering why they are so hard to find. anything you have can tell me about them is greatly appreciated | | |
