1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
Junior Member
Junior Member
Seems like I read somewhere that my 1952 2 ton came with a choice of only two, two-speed rear ends. Does anyone know if this is true and what the gear ratios of the choices was/is? I've owned a similar size IHC and they used Eaton rear ends and had numerous choices for their 2-speeds. Thanks for the help.
According to the reprint of the Chevrolet Truck Shop Manual 1948-50 2-speed axles had 6.13 & 8.10. It doesn't show ratios for '51-up so I would assume nothing changed.
2-tons with 1-speed axle were 6.17.
Only one Two speed rear axle was available in Chevrolet Advance Design Trucks, & that was a Timken 6.13 - 8.10 , GMC's came with several different Eaton 2 spd.'s depending on the series.If you have a Eaton, chances are it's out of another truck.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Junior Member
Junior Member
heelo again--you recently answered my parts wanted add for a 48 chev rear axle--i was wondering if you had one or knew of any other make than ran these rearends. also i was wondering why they are so hard to find. anything you have can tell me about them is greatly appreciated
