0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | This is just a generic 4 link question on an installation:
I have the 4 link ready to go and will be installing it with the rear at ride height and at half travel with the lower bar parallel to the ground. As I set up the coil overs, should I also have the shocks at half travel? This makes sense in my mind, but wanted to ask someone with more knowledge than I have. The way I view it is that, this way, when overextending, the shock will have scope to move out. Correct?
Also, what is your view on installation angle? Vertical or angled? I would prefer to mount these vertically (space), but am open to suggestion.
Thanks Bolters. | | | | | Joined: Mar 2007 Posts: 3,497 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,497 | Fox, You may want to search "Shock Mounting". I had a great discussion with HRL (Jerry) and a few others on proper shock mounts and angle. As it turns out 45 to 90 degrees is optimal for installation and travel.
I haven't installed a 4 link as yet although it's in the plans for a friends F**d truck later this year. Good luck.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
