Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Tony292, baldeagle), 32 guests, and 3 robots.
Topics128,003
Posts1,055,244
Members48,418
#1418011 07/24/2021 9:33 PM
I need the measurement shown in the example pic, but from a 16" wheel for a 47-55 1st. The distance from the outer edge of the rim to the surface the hucap sits on is what I'm looking for. Thanks
1950 Chevy 3100
In the original Gallery
More pix and update in the Gallery Forums
1952 Chevy 1/2-Ton Deluxe Cab
1957 Chevy 210 4dr
1957 Chevy Belair 4dr
1964 Nova 400 4dr
.....................................crickets..................................................................
1950 Chevy 3100
1957 Chevy 210 4dr
1964 Nova 400 4dr
bowtie john
attached is a pic of my 16x6 6 lug the distance from the rim edge to the hubcap rise is only 5/16"
1936 Chevy 1/2 ton pickup
Thank you so much that's just what I needed!
1950 Chevy 3100
1957 Chevy 210 4dr
1964 Nova 400 4dr
I think that measurement might differ over the AD years, as early wheels started out as 4" wide, then went to 4-1/2" wide, and they were probably all zero offset, so that might make that rim edge to inner dish surface dept vary by as much as 1/4". Wider wheels would probably be a larger dimension that later wheels. I measured three 4-1/2" wide wheels and got 3/8" on one and 7/16" on two others.
1950 models had 4 1/2 wheels if I remember correctly? So 3/8 or 7/16 are the numbers I'm looking for. Thanks
1950 Chevy 3100
1957 Chevy 210 4dr
1964 Nova 400 4dr
someone told me my pinstriped wheels were from '47. not sure.
They were all pinstriped. The only way to tell is to measure the width. Early trucks were 4" wide and later (not sure of the cutoff year) were 4.5" wide.
I've got 1, pinstriped, 16" 4" wide. Can post pics later if you want.
BC
1960 C60 pasture art
