2 members (2-Ton, Peggy M),
151
Mod | | | Forums66 Topics128,105 Posts1,056,538 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2020 Posts: 23 'Bolter | | 'Bolter Joined: May 2020 Posts: 23 | I have a c60 up and running but having trouble getting the hydrovac dialed in. Does anyone know of a shop that will work on this truck? I live in Gilbert, trying to find a shop in the East Valley. | | | | | Joined: Nov 2019 Posts: 150 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 150 | What specifically are you having problems with? Bleeding procedure or possible faulty parts? Is it pedal problems? The hydrovac diaphragm does go bad and allows fluid past and into the vacuum line which can then be sucked to the intake.
If it is faulty parts, very few (if any) local shops have the know-how for a truck that size and age let alone ability to repair/rebuild and replacements don't directly exist. Good reputable shops can rebuild your current unit, but you have to take it off and ship it out for the rebuild. If you go this route, it is best to have them do the master as well. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Phoenix Brake and Clutch should be able to help you. They are off of I-17 near Thomas Rd. | | |
