3 members (KEVINSKI, Gray_Ghost, Otto Skorzeny), 113 guests, and 4 robots.
Topics128,100
Posts1,056,513
Members48,448
I have a c60 up and running but having trouble getting the hydrovac dialed in. Does anyone know of a shop that will work on this truck? I live in Gilbert, trying to find a shop in the East Valley.
What specifically are you having problems with? Bleeding procedure or possible faulty parts? Is it pedal problems? The hydrovac diaphragm does go bad and allows fluid past and into the vacuum line which can then be sucked to the intake.
If it is faulty parts, very few (if any) local shops have the know-how for a truck that size and age let alone ability to repair/rebuild and replacements don't directly exist. Good reputable shops can rebuild your current unit, but you have to take it off and ship it out for the rebuild. If you go this route, it is best to have them do the master as well.
1964 Chevrolet C60 Real Farm Truck
in Gallery Forum
Phoenix Brake and Clutch should be able to help you. They are off of I-17 near Thomas Rd.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
