6 members (Bill Hanlon, Hotrod Lincoln, greenie-reddy, 1955 1 Series, Otto Skorzeny, Phak1), 172 guests, and 3 robots.
Topics128,108
Posts1,056,228
Members48,436
So far on my project truck I have done all of the sheet metal cutting with cutoff wheels in a grinder. This seems OK for most things, but not always. I'm curious to know what alternatives you guys use. I realize that a plasma cutter is probably the ultimate tool for this, but I kinda doubt that I'll be laying out the money for one because I dont really plan to do any more of this type of work after this truck. I do have a bench top shear, but I find that it is only good for 22 gauge or lighter, and of course only for straight cuts.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
I haven't used a plasma in some time now. My go to seems to be the bandsaw whenever possible!
I have found an air operated reciprocating body saw, or saber saw, to be very helpful with cutting irregular shapes and smaller circles that cutoff wheels cannot make. Just buy a lot of extra blades as they wear out much quicker than cutoff wheels.
Charlie
'51 3100 5-Window (Restomod in progress)
Mike
I have a sheet metal nibbler that attaches to a drill motor. I recall it cost me $25 on Amazon. I also have a sheet metal saw from HF like Charlie suggested above.
The nibbler is great for cutting irregular curves. Here's a picture of it. I also used it to do the cutout for this patch in my fender.
But when using it you have to watch out for the sharp little crescents of metal it leaves behind. The Missus won't want you tearing up her floors when they stick in your shoes. nono
I bought a plasma cutter also (one of the cheapo ones supposedly rated for 1/2 inch steel thickness), but rarely use it because you need to setup the plasma cutter, connect the compressor up, etc. etc.
I have some air shears (like air powered tinsnips - pistol grip) good to 18 gauge that are an absolute blessing for cutting (clean) sheetmetal. Last forever with care (unless you try and cut rusty sheetmetal). You can do wide radiuses fine. They also produce a nice consistent curl of sheetmetal about 1/4" wide that comes in handy frequently for little gaps and such.
Also have some air nibblers that as klhansen says above, work fantastic for tight/odd/sharp angles - but I second that "watch for the little crescents". They get everywhere and somehow find their way into the house. I worry about the shop cats too, I use those over a bag/container where possible and keep a magnet handy. Even at that, some escape.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
The cutoff cutting wheel is my go to. The plasma cutter is nice but you have to be careful with what may be underneath the piece you are cutting. It is not forgiving.
Moderator, Electrical Bay
I usually use a saber saw and a metal cutting blade for sheet metal. Cheaper, quick enough and plenty accurate enough if you have a steady hand.
~ Jon
Insomniac
Insomniac
+1 on the saber saw. Wear ear defenders!
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Bill's Tin Snip video:
AD Addict & Tinkerer
WOW! 50 years of using tin snips and I thought I knew how to use them. I learn something new everyday! Great video and thanks Robert for sharing!
dang
Phil
Project Journals
Stovebolt Gallery Forum
Here's a video of a hole I cut for a fan shroud.
Before I watched Bill's tin snip video my fingers would have been shredded from all the burrs. So yes, I fit in that same category, saw what I have been doing wrong for so long.
I used them for several years putting up acoustical ceiling and picked up many a pair for free.........it took the rookies a while to figure out you need have to keep the cutting jaws clean to keep them running smoothy.
......well, I'd usually be a good guy and show them and give them their snips back!!!
.....I have one of each in my tool box. All swiss!
I go thru a lot of Dremel metal cut off wheels, and have also burned thru three Dremels but I like the small wheel, and control I get. I may have to look into the nibbler.
