| | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 51 Member | | Member Joined: Jan 2000 Posts: 51 | I'm going to replace the clutch on my 37 1 1/2 ton truck. What is the diameter of the clutch plate? they don't look easy to find NOS so I'm thinking of having it refaced at Rochester Brake and Clutch [they have been doing it for decades] anyone have a part # as I see them on ebay from time to time. Appreciate all your thoughts... Gary | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It is very probable that the clutch in your truck has been changed several times in it's 60+ years. I tried two different listed ones from NAPA for my '53 2-ton and neither fit. Then I took mine to a rebuilder and got it done for a little over half the price of the new one and it fit. | | | | | Joined: Jan 2000 Posts: 51 Member | | Member Joined: Jan 2000 Posts: 51 | Cletis, Thats the way I'm going to go, no sense buying ebay and not getting the right thing. Enjoy your web site, want to know if thats a pto driven winch on your yard dog? That set-up is slick!!! | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 |  Found it. Knew I had 1. I have an after market NOS clutch it's twin is in my 38 1 1/2 ton it seems to be approximately 11 inchs diameter.maybe 10 3/4 if I'm not straight. Manufacturer is Burgess-Norton. Part number CF-3803. Just read a little closer it's for 38 thru 42 oh well post it any way maybe the numbers will help some one else crossreference theirs. Price on box will hurt your feelings.three dollars and fifty nine cents . Wonder what they go for on ebay | | | | | Joined: Jan 2000 Posts: 51 Member | | Member Joined: Jan 2000 Posts: 51 | yes the 38-42 clutch is different, I think the years are 32-37 for the one I've got, will post the diameter when I get the thing out-probably be a couple of weeks yet before I get to it!!! will keep you all posted... thanks | | |
