8 members (Wickedbass, tclederman, Rusty Heaps, Peggy M, TexasA&M48Truck, Wally / Montana, Gray_Ghost, UtahYork),
115
Mod | | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2021 Posts: 2 Moderated | | Moderated Joined: Jul 2021 Posts: 2 | Hey all
Im working on a chevy 4400 rig and have a question about a carpet/floor rubber kit. I went to order a new floor rubber molded floor kit(same as a carpet kit) but rubber from brothers truck parts. The order person said it would not fit and would be to small because all the parts they sell are for standard 55 chevy and not the 1 ton plus. Anybody know if that is true or is the cab size about the same. If not the same size where could i get a new floor kit
Shortmagnum | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Front sheet metal/hood may be different but cab should be the same as far as flooring would be concerned. John 1949 gmc 1-ton | | | | | Joined: May 2015 Posts: 11,049 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,049 | The only cab that would be different would be the COE. And even that might use the same floor mat. The difference is in the door opening. Welcome to the Stovebolt forums, Shortmagnum. You should go to the Welcome Centre and tell us a bit about yourself and your truck.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Welcome to the Stovebolt  As a general rule it's always nice to tell us if you're working on a first or second series 1955 truck with each question... Mike B  | | | | | Joined: Jul 2021 Posts: 2 Moderated | | Moderated Joined: Jul 2021 Posts: 2 | Thanks guys. First time ive ever posted on any forum. I bought this 55 chevy 4400 as a retirement project. Its a series 2. Ive been slowly poking along with this but have had some serious health stuff pop up so it went to a back burner. Trying to clean it up for the kids(my health stuff was definitely the word you dont want to hear) im trying to put some nice fun easy cruising time on it. I want to clean up the interior but leave the old school patina on the outside. Thank you for your replies. Ill get better at this as i run into questions. Thank you all | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | EVERYTHING inside your cab is the same as the 3100 pickup (dash, seat, 4-speed floor covering, windows, etc.). The only different sheet metal will be the fenders, upper and lower grill panels and the grill bar. The cab, doors, inner fenders, hood, core support and hood latch panels are all the same as the pickup. Mike B  | | | | | Joined: Feb 2019 Posts: 87 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 87 | Make sure they have it in stock! I ordered a floor mat for my 1969 C60 from them and it took months and months to get, off the top of my head I think it was 6 months. | | |
