1 members (baldeagle),
70
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 15 New Guy | | New Guy Joined: Oct 2004 Posts: 15 | Need to id my 46 Chevy truck. The title id number is DEA516983 it of course says it a 46. My id plate on the truck has a different number, 8PWL5829. It also shows GVR at 15,000 lbs. Even on a big truck shouldn't the number on the title match the one on the id plate?
1946 Chevy Flatbed 2 Ton Truck 1950 Chevy 3100 5 Window Cab P/U 1968 Chevy CST 1972 Chevy Fleetside Longbed 1992 Chevy Scottsdale Ext Cab 2000 GMC Sierra Ext Cab | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Some times they go by engine serial number on the title | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | That number from the title is an engine number. Do you still have the orginal motor?
The other number looks right, but I don't have my VIN code book handy, so I can't intrepret it right now.
-8 is where it was made. -P is the year. -W is the model. Usually the two letters are associated with each other in the vin keys you'll find. They use a different year letter on big trucks than on small. I don't know why. -L is the month, December in this case.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2004 Posts: 15 New Guy | | New Guy Joined: Oct 2004 Posts: 15 | Far as I can tell the motor is the original 235. Also does anyone know of a place where I can get a factory assembly manual or a manual that is specific to this model and size truck? I need to figure out how to remove the rear drums so I can work on the brakes!
1946 Chevy Flatbed 2 Ton Truck 1950 Chevy 3100 5 Window Cab P/U 1968 Chevy CST 1972 Chevy Fleetside Longbed 1992 Chevy Scottsdale Ext Cab 2000 GMC Sierra Ext Cab | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Using the Deciphering Your Chevy VIN and the Series and Model Codes tech tips here on the 'bolt (doesn't anyone leave the Forums  ), the ID breaks down like this: 8 - Built in Atlanta, GA PW - 2 Ton L - Assembled in December As kb and Steve pointed out, many jurisdictions titled these old trucks using the engine serial number rather than the truck ID number. Could be problematical if the engine is ever swapped out. You might want to see what it would take to get your title "corrected" (never tell DMVs that you want to "change" something) to match the ID plate.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Good luck with that chevy resto pack, man.. I ordered one and they had it to my house in less than a week.. but it was for CARS. I called them again, told them dude.. I have a two ton truck, not a car.. oh geeze i'm sorry lemme send out a new one. I got ANOTHER one for cars.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Fumblin46: I got ANOTHER one for cars. Did you give them the VIN number or the motor number? I have received stuff from them that did not make sense. Ever. But its worth the effort because those packs have a lot of good info in them.
