| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 117 Member | | Member Joined: Sep 2004 Posts: 117 | I got my restoration pack from chevy today. I still can't decypher the Serial # 4C653 B 107177. The 653 don't match? Chevy says it should have 13 numbers I copied it right off the door jamb and it looks like new, so no problem reading it. What am I doing wrong? 4=1964 C=Conventional B=Baltimore 107177= 7,177th built so,what is the 653? | | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Hi Don Check out my VIN Decoder Page for a breakdown of the VIN. 6 = 2-ton 5 = ?? 3 = Cab & Chassis To this day I still haven't a clue what the second numeral behind the Series Designator means?? Hope this helps?? | | | | | Joined: Sep 2004 Posts: 117 Member | | Member Joined: Sep 2004 Posts: 117 | thanks, Bergie no big deal...anyone can see it's a fire truck,lol | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I'll repeat others and add a little: 4 = 1964 C = Conventional with gas engine 6 = 2 ton rating 5 = 175" wheel base 3 = Cab Cahssis B = Baltimore 107177 = unit number starting with 100001 (7,177th unit built at Plant "B") Mike  | | |
