4 members (TexasA&M48Truck, 32Fordpuchoptop, TUTS 59, 1 invisible), 47 guests, and 4 robots.
Topics128,021
Posts1,055,349
Members48,420
#141677 02/26/2005 12:16 AM
I got my restoration pack from chevy today. I still can't decypher the Serial # 4C653 B 107177. The 653 don't match? Chevy says it should have 13 numbers
I copied it right off the door jamb and it looks like new, so no problem reading it.
What am I doing wrong?
4=1964
C=Conventional
B=Baltimore
107177= 7,177th built
so,what is the 653?
#141678 02/26/2005 1:48 AM
Hi Don
Check out my VIN Decoder Page for a breakdown of the VIN.
6 = 2-ton
5 = ??
3 = Cab & Chassis
To this day I still haven't a clue what the second numeral behind the Series Designator means??
Hope this helps??
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
#141679 02/26/2005 4:08 AM
thanks, Bergie no big deal...anyone can see it's a fire truck,lol
#141680 02/27/2005 3:06 AM
I'll repeat others and add a little:
4 = 1964
C = Conventional with gas engine
6 = 2 ton rating
5 = 175" wheel base
3 = Cab Cahssis
B = Baltimore
107177 = unit number starting with 100001 (7,177th unit built at Plant "B")
Mike smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
