| | | Forums66 Topics128,130 Posts1,056,367 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 109 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 109 | I have a 1954 chevy 3100 with original 235 and the carb has given me fits. The air fuel adjustment at the base snapped off when I was trying to dial it in. Is there a bolt on replacement that might be a better option than the Rochester? I was reading Carter ya 966 was a good option but wanted to verify. Also where can one be purchased? Thanks
Matt | | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | Hey, Matt.
Think I answered you on one of the FB groups... look for Carter YF 2101S for the '54. The 966S was spec'ed as a replacement for the 235 through '52. Probably work, but the newer spec carb should be a better match. They pop up on eBay from time to time - there are 3 or 4 cores listed now - but nothing that looks great at the moment.
You might want to post to the Swap Meet "Parts Wanted" forum.
Cheers,
Doug | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | The 2101S is an auto choke as I recall. Some people (me in that group) prefer that type, but some want the manual choke and if that's what you want the 2100S is the one you could search. It is also possible some of the Carter manual choke carburetors made for the 230 could work for you. I've got two of those listed in the parts for sale section (YF 4145S models).
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
