3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1415974 07/05/2021 5:55 PM
I have a very annoying squeak coming from my 1966 C10 driver's-side, upper control-arm shaft and end-cap. When tightened, the end cap is right up against the end of the shaft and will not allow any grease to enter the cavity. Therefore, the threads are dry and squeaking badly.
The end cap is also eating into the side of the A-arm. I bought some large grade 8 washers and had a machinist enlarge the hole just large enough to fit over the end-cap shaft to stop the end cap from eating into to A-arm and provide some space for grease. But unfortunately, when tightened, I cannot force any grease into the threads. A pressure grease gun cannot do it either. So, the threads dry out and squeak. The only solution I have found is to remove the end-caps periodically, manually grease the threads and put it back together again. A very poor design.
That's a lot of work to stop a squeak every few months.
Any suggestions?
Reup
1964-66 Shortbox Stepside
"Little of this, little of that"
Reup I am moving this to another forum in case we can get more response.
~ HB
1962 Chevrolet C10
1962 Suburban
Actually it's a pretty good design and was used for many years. However things do wear out. More than likely the bushings and possibly the shafts are worn out. Another possibility is damage to the A arm itself from an accident. It's hard to notice that type of damage unless it's obvious. A lot of stuff happens over the years. Complete A arms, shafts, and bushings are available through a variety of aftermarket suppliers.
Fred
