6 members (NJC, Gdads51, joe apple, 3B, 3800GUY, 1 invisible), 83 guests, and 1 robot.
Topics128,130
Posts1,056,367
Members48,441
GPK 1961
GPK 1961
Hello all and Happy 4th of July.
61' Apache 10 - 235 cubic inch engine with a 4-speed manual.
Does anyone know the bolt size to mount the slave cylinder to the bell housing? I seem to have misplaced these.
I mounted my rebuilt 4 speed to the bell housing yesterday (talk about dead weight!)
Should the clutch fork be able to move at this point?
Thanks in advance. GPK1961
New project - 1961 Apache 10 Step-side
With the trans installed the clutch fork and throw out bearing should rattle around a little with the linkage not connected.
If you're trying to disengage to clutch using the fork, that takes leg power or a pry bar as most of us are not be strong enough push or pull the fork by hand.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
GPK 1961
GPK 1961
Thanks, Mike B -- I thought it would be tight against the clutch assembly. Now on to the hydraulics!
