I mounted my rebuilt 4 speed to the bell housing yesterday (talk about dead weight!)
Should the clutch fork be able to move at this point?
With the trans installed the clutch fork and throw out bearing should rattle around a little with the linkage not connected.
If you're trying to disengage to clutch using the fork, that takes leg power or a pry bar as most of us are not be strong enough push or pull the fork by hand.
Mike B
