0 members (),
129
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2021 Posts: 69 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 69 | Hi guys , the truck i bought doesnt seem to have a park brake assembly in the cab are there any different years that will fit my 54 3100 ? Or does anyone know of or have a source for the park brake pedal assembly ? thanks | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | '47 models that had a floor shifter had a hand parking brake lever alongside it, but from '48-55 1st, Chevy used the parking brake pedal at the left kick panel. So should be readily available. You might try posting an ad in the Swap Meet. Another 'bolter may have what you need laying around.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Or this link shows all the parts.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2021 Posts: 69 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 69 | thanks forr the help guys if ya know where i can get an assembly let me know | | | | | Joined: Jun 2021 Posts: 69 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 69 | well, it turns out the park brake assembly was under the seat , hopefully it will install easily on the truck , thanks for the help guys | | | | | Joined: Jun 2021 Posts: 69 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 69 | Btw trucks of the 40's carries a lot of parts needed for my 54 park brake . | | |
