| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Hi all, I have a line on a dump box from a TF truck [img] https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/32109/filename/Dumper.jpg[/img] Has anyone added a dump box to a frame that did not have one originally? I have a 3600, but am curious if I would have to cut out cross members to make this work? I will be pulling the transmission in the near future, so adding the pto can be done then, but I won't bother if it's too evasive to do. Thanks! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Goach2, it looks like the frame for the dump box hydraulics is sitting inside the frame of the truck it is on, we can't see both sides of it from your picture, but if it the same on both sides it may have to be removed with a cutting torch. I've never seen one like that before, most dump frames sit on top of the trucks chassis, not inside of it, I'd steer clear. | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Thanks 3B, I was thinking the same, plus my frame has the wheel 'hump' and I don't know how it would work with this set up. Is it worth grabbing the hydraulics? Or just wait for something complete AND compatible? | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Goach2 Made a 4 ton dump box out of oil tank steel for my 48 2 ton,not easy but works fine. Tank steel never forgets it was round but you can overcome that with your torch and arc weldor. | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Fixite7 - I'd like to see that! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Goach2 Put on a picture of my 51 6400 daily driver,maybe you saw it. My posts disappear a lot,Martin says trouble is with my computer I think he is right. Im no 'puter gooroo ! If I can get a handle on pictures will show that bed. If not could maybe send you some phone pictures,they PM but not sure how to do that either. My 51 6400 has a tank steel bed too,picture is not very good. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Goach2 Hadn't heard anymore from you,if you can receive pictures call me 618 707 9582 will try to send you some pictures of that gravel bed. Handles about 8000 lbs of white rock,your frame looks like a candidate foor the same thing. Gross about 15000 E.W. 7000. | | |
