4 members (baldeagle, Wayne67vert, Joe H, Nuts&Bolts), 65 guests, and 1 robot.
Topics128,014
Posts1,055,331
Members48,419
#1413016 06/07/2021 7:43 PM
Hi all,
I have a line on a dump box from a TF truck
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/32109/filename/Dumper.jpg[/img]
Has anyone added a dump box to a frame that did not have one originally? I have a 3600, but am curious if I would have to cut out cross members to make this work? I will be pulling the transmission in the near future, so adding the pto can be done then, but I won't bother if it's too evasive to do.
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
3B Offline
Hy Goach2, it looks like the frame for the dump box hydraulics is sitting inside the frame of the truck it is on, we can't see both sides of it from your picture, but if it the same on both sides it may have to be removed with a cutting torch. I've never seen one like that before, most dump frames sit on top of the trucks chassis, not inside of it, I'd steer clear.
Thanks 3B, I was thinking the same, plus my frame has the wheel 'hump' and I don't know how it would work with this set up. Is it worth grabbing the hydraulics? Or just wait for something complete AND compatible?
More images
You could look into one of the modern electric over hydraulic systems like this one. By the time you buy a PTO to fit your SM420 and rebuild an old hydraulic pump system you may be money ahead.
https://www.piercearrowinc.com/prod...jvjpV8BmThrNEmsRIUrYUMa1nlRoCuGcQAvD_BwE
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Goach2 Made a 4 ton dump box out of oil tank steel for my 48 2 ton,not easy but works fine. Tank steel never forgets it was round but you can overcome that with your torch and arc weldor.
Fixite7 - I'd like to see that!
More images
Goach2 Put on a picture of my 51 6400 daily driver,maybe you saw it. My posts disappear a lot,Martin says trouble is with my computer I think he is right. Im no 'puter gooroo ! If I can get a handle on pictures will show that bed. If not could maybe send you some phone pictures,they PM but not sure how to do that either. My 51 6400 has a tank steel bed too,picture is not very good.
Goach2 Hadn't heard anymore from you,if you can receive pictures call me 618 707 9582 will try to send you some pictures of that gravel bed. Handles about 8000 lbs of white rock,your frame looks like a candidate foor the same thing. Gross about 15000 E.W. 7000.
