4 members (Slick Willy, Otto Skorzeny, 1955 1 Series, Rexville48), 66 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#1414638 06/23/2021 11:43 AM
hi guys newbie to the forum here . my question is this im taking delivery of a 1954 chevy shortbed soon . i dont care for the grille ( il call it a bull nose) and what i would like to do is replace it with the bar style from a earlier year is that gonna be doable without any major mods ? Thanks
It’s done all the time. I don’t believe it requires any major modifications.
Fox Offline
I think the 54-55 front fenders will have depressions from where the grill bars and signal lights wrap over, if I remember correctly. Someone else needs to confirm this though.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
The 1954 grill attached differently to to 1954 fenders.
This could be easily made to work - probably
The 1954 fenders have the side-lights/lamps in the fenders.
The earlier A-D grills have the front side lights attached/mounted in the grill assembly.?
Leave those holes/indentation or fill those areas?
(I posted this while Fox posted is comments.)
Let's play together nicely.
Here is a picture of those fenders and the depressions described above.
https://www.flickr.com/photos/advance-design_parts_co/28812818104/in/album-72157631868452754/
mikeg103 #1414743 06/24/2021 12:44 PM
AD Addict & Tinkerer
Here is a picture of a ‘52 for comparison.
Phil
Project Journals
Stovebolt Gallery Forum
mikeg103 #1414744 06/24/2021 12:50 PM
The radius on the corner of the grille opening looks sharper on the early AD’s.
Maybe some ‘bolter, that did this swap can chime in!
Phil
Project Journals
The radius inboard of the headlight opening is definitely sharper on earlier fenders.
Here's a pic for comparison with Brad's.
One could modify the later fenders, but it might be easier to swap them with the earlier ones. '54-55.1 fenders are likely scarcer than the early ones. If you find someone with a 54-55.1 who desperately needs fenders, you might be able to get some decent early fenders in a swap.
thats great info , thanks guys ! I have a classic industries catalog and i guess the fenders in there should fit has anyone had any experience with their parts ? good fit or no ?
You will need to assemble the entire front clip (preferably before paint) and check the fit of aftermarket parts, especially the top of the fender openings where they meet the grill.
The grills don't usually fit original fenders in that area, and I doubt that they fit aftermarket fenders. The radius of the corners aren't right.
mikeg103 #1419200 08/03/2021 12:45 AM
Most everyones replies are correct.
Its NOT done all the time. ~~~ unless you have a 47-53 front end to use for parts. Fenders,splash pan, hood, emblems, etc.....
It DOES require major mods. ~~~ changing the fenders, splash pan,, etc. And keep in mind, youre ruining a '54.
You may as well butcher out the dash, to switch with a 53, also try to fit a 2 piece windshield in place of the one piece.
