This is my plan for the dash and cab areas, looking for feedback. My dash is not as bad as this sample piece. I might sand it instead of wirebrush. Then Ospho, rusty metal primer, and Rustoleum Dark Bronze metallic 7272-830.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
