2 members (jmoore, baldeagle), 150 guests, and 1 robot.
Topics128,037
Posts1,055,469
Members48,424
#1414127 06/17/2021 3:45 AM
Hey all, I'm working on my '53 Chevy 3600 front leaf springs and have a question, On the front leaf spring rear hanger the leaf spring goes inbetween two hanger mounting points and the eye bolt goes throught it all to hold the leafs in place, my question is, are there meant to be threads in both sides of the hanger mount or just the inner side?
inner side.
1946 GMC Project
"Back-in-the-day Restore"
That figure (probably generic just to show parts positions) shows a fully threaded bolt at the rear, along with a threaded bushing, but on my '51, the fixed spring mounts (rear on the fronts and front on the rears) use a smooth bushing and bolt that threads into the inner side of the spring mount with a jam nut on the inside.
Here are some of the parts pictured if that helps
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Inner does make sense, as the threads are only on the inner side of the bolt and the rest of the eye bolt is a constant thread height diameter. When I pulled my eye bolt out I noticed what looked like faint threads in the outer mount and was worried that the mount was worn out because "the threads were worn off" but it does appear that the eye bolt just left behind threads marks as it came out. that's a relief. thanks everyone for coming in. have a great weekend!
