5 members (Wayne67vert, Gray_Ghost, tclederman, Ridgeback, 1 invisible), 56 guests, and 5 robots.
Topics128,021
Posts1,055,372
Members48,420
CPP5559PSK-OC
https://www.classicperform.com/Store/1960_1972_Chevy_Truck/CPP5559PSK-OC.htm
I was looking at this but not sure of the clearance I have will be enough. I called CPP (terrible experience to be honest, was on hold for over one hour and that was after numerous messages and emails were never returned). The tech said it has 5.9" of clearance from the flange to the furthest point opposite but was unsure if that included the bolts or not???
I have about 1" of clearance right now with my exhaust manifold to the existing steering box. I have a Big Block and using corvette exhaust manifolds that give me very good clearance as opposed to original stock exhaust manifolds.
Even with the corvette manifolds I just dont know if this unit will fit. If anyone has this installed could you please give me some measurements of how much space it takes up starting from the inside of the frame rail where the flange bolts up?
Pics would be great too
Thanks in advance
Frank V
If not any suggestions on a different unit or setup
Frank
1948 5 Window Chevy 3100 an absolute rescue that is now back on the road
1953 Buick Super 1 family owned since new
1956 3200 Big Window
1985.5 Mustang SVO
1986 Mustang SVO
That steering box is an aftermarket reproduction of the 84-87 Toyota steering box. It is sold by a variety of vendors and is also known as a 500 series. I have the original version of the Toyota box in my 56 which I installed in 2000. It has been trouble free. The box is close to the left rams horn manifold but clears ok. The later version moves the box closer inside the frame which may clear a big block. I have not seen one installed on a TF truck with a big block so I could only speculate as to the clearance. If you only have about 1" of clearance now it likely won't work.
Fred
It might help others help you if they knew what truck you are working on...the kit says 1960-72.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Yes the link does say 62-72 but the kit is 55-59.
I am working on my 1956 3200
Frank
1985.5 Mustang SVO
1986 Mustang SVO
