0 members (), 163 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
Hi, I am looking for a source for the "fish-eye" beige paint for a '46 truck. Last I new jim carter's had it under code PT106 but it is no longer listed on their website. Anyone have any luck on substitutions? Thanks for any help!
1939 Chevy 1 1/2 ton with 216
Someone several years ago here on the SB recommended Rustoleum Hammer tone Dark Bronze as a substitute paint for the dash and related interior parts. I used it a few years ago and compared the color and texture to remnants of the original paint found on a few pieces of my ‘46 project. It was a very close match.
Attached is a photo of the paint can and recommended mix from Rustoleum. The representative I talked in getting some other questions answered suggested a 3:1.25 paint to xylol for spraying. That mix combination worked well.
Also attached is a photo of the painted dash.
Last edited by 46Sparky; 06/11/2021 5:38 PM. Reason: Error in mix ratio was corrected
JC uses PT133 as a replacement for PT106.
https://www.oldchevytrucks.com/cart/product.asp?prodid=PT133&i=|||||
Call 800-862-1913 and ask them the difference in the 2 paints.
Harold
Harold
That dash came out really nice, I think that is what I will do when it comes time to paint, thank you for adding the mix ratio as well.
Note:
The mix ratio was incorrect and the post edited to report the correct:
3:1.25 paint to xylol.
That paint color is also available in rattle can. For some reason using it as a touch up over the mixed version didn’t work well for me. In installing one of the garnish molding parts I managed to scratch it. I figured the rattle can would be a quick remedy. Not so. It blistered. The part needed stripped again and a complete do over.
