8 members (TUTS 59, Otto Skorzeny, GMCJammer51, Jon G, 1955 1 Series, Joe H, TexasA&M48Truck, Bill Hanlon),
180
Mod | | | Forums66 Topics128,078 Posts1,056,044 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 4 Junior Member | | Junior Member Joined: Oct 2002 Posts: 4 | Hello Folks: Two questions. One here, one elsewhere. Upon reflection, both here: (1) Can anyone assist interpreting VIN for '63 C60? VIN = 3C653S152092. Have called Chevy for Restoration Pack but have been told is too old and information will not be complete. Help... (2) Four wires from firewall plug. One wire is hot continuously regardless of ignition switch position, one hot with ignition 'on' (to coil??)and one to solenoid "S" terminal to start and other for water temp sensor. Question: What does "R" on solenoid terminal mean? Where does the always-hot wire go and why? All help appreciated. /s/ Stubby | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Restoration Pack won't answer your electrical questions. I've received REstoration Packs on my trucks built in the '50s so I'm surprised they say your '63 is too old...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2004 Posts: 17 Junior Member | | Junior Member Joined: Aug 2004 Posts: 17 | I had the same problem with the restoration package for my 49. Frist time I call for one they said they did not have them for that year. Was advised to call back by some of the guys at stovebolts and try again. They said I might have got a lazy person the first time. Secound time was a charm, have package coming, was told it was not spacificlly for my truck size, but year class.
So try calling them back till the send you something. good luck. | | | | | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | Most '63 to '74 vehicles used a points and condenser system, with a resistance wire enclosed in the harness (from the firewall to the coil). The wire (yellow) from the "R" terminal of the GM solenoid routes to the "plus" terminal of the ignition coil, and its purpose was to bypass the ballast resistor during cranking for hotter spark. If you have an electronic igniton, there is no need for this wire. | | | | | Joined: Aug 2004 Posts: 17 Junior Member | | Junior Member Joined: Aug 2004 Posts: 17 | update on restoration package,
I am shocked received my package yesterday, was told it might take 6-8 weeks to receive. So if you have not called them back try again. lots of good stuff in there. they sent me a package for both 1949 cars and trucks.
good luck with getting yours. | | |
