3 members (Dennys28, Southerntruck, KEVINSKI), 82 guests, and 0 robots.
Topics128,156
Posts1,056,870
Members48,456
#141295 05/30/2005 6:25 PM
Recently bought this rear axle for installation in my '38 ton and a half whenever I get around to picking up that project.
Width across the axle flanges is 66.5". Weight rating is 11,000 lbs. Gear ratio is 4.63. Wheel bolt circle is 10 on 7.25", wheel hub pilot is 5.25" in diameter.
It is a Dana 80 from a '99 1/2 GM truck according to the assembly numbers on it. The Dana websight has Parts Lists and Service Manuals on line for it. This rear end appears to be popular with the 4 wheeling crowd so there are lots of parts/tools available for it.
Motorhome / 3500HD rear axle
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
looks nice, whatcha gonna do for brakes on the front?
Do a search on this site for Dana 70HD. I did a similar swap on my truck, you will find some pictures and discussion about it.
Have fun,
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
grigg,
I'm thinking of adapting front spindles and brakes from the same vintage truck to the front axle. Another bolter here (Winky) has had it done so I know it's possible.
Sorry about the delay getting back, I'm on the road for work again.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
Junior Member
Junior Member
sure did, I have a rolling frame now with 4 wheel disc brakes. smile The spring perch for rear axle was cut off and moved out about 1/2 inch,still has room for brake lines. Old rims can be used by changing center hole.New wheels look just as good.Hard core might see the difference. cool
Winky,how'd you do your front brakes? Were you able to keep the stock axle,or did you have to adapt the newer one in?
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#141300 06/04/2005 11:44 PM
As you may know I adapted an entire front axle.
But I was at a truck show yesterday and saw one with adapted spindles with the old I-beam, disc brakes all the way around. E-mail me and I can send you a few pictures of the truck at the show.
Grigg
---All pictures---
Junior Member
Junior Member
I used my old/orig front axel because I dont feel very good about welding an axel back together. I took spindles from p30 and axel to shop for new kingpins he rebushed to fit.I have lots of picts I posted before,search should turn them up,if you cant find let me know I will post again.I think it cost about 500 bucks for machine work,spindles,kingpins. new tie rods are needed [take from p30 ] shorten cross tube on passenger side,it has right hand threads. cool
