5 members (Ridgeback, Phak1, Tinker5, Joe H, GMCJammer51), 61 guests, and 0 robots.
Topics128,196
Posts1,057,398
Members48,471
I am thinking of using Bondo type filler on the interior of my cab to help hide weld seams on patch panels and such. I can't see any reason not to do that, but I thought that I'd just check with the vast experience of this list first.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Why not? It works on outer panels, and they are out in the weather. I use body filler on the interior. Work fine, last long time. Fy dolla.
Moderator, Electrical Bay
Bondo is fine and if you have small seams, etc J.B. Weld can be used. It sometimes makes a better sanding surface than Bondo type fillers (which can suffer air bubbles). Also...and some may find this a negative, but I certainly don't...if you use J. B. Weld, you can use J. B. Kwik-Weld and slow the set-up time by adding slightly less than 50% hardener or you can use the regular J. B. Weld which sets up much slower. This gives you time to get things just right. With Bondo and typical fillers, I find they tend to set up too doggone fast...often while you're trying to paddle them on the metal.
~ Jon
Devcon has an industrial quality product that's far superior to J-B Weld. It's called "Plastic Steel". The regular stuff has a 45 minute cure time, and there's also a 5-minute quick setting version.
https://itwperformancepolymers.com/...ding-repair/devcon-plastic-steel-putty-a
Jewrry
Curmudgeon
Curmudgeon
If you have a typical lap-weld with a raised bead down the seam, for strength, then you may not be happy with any of the Bondos and epoxies. This would be a panel that is visible and not something on the floor that you cover with a mat. You fill-in along each side of the bead and sand smooth and uniform but it will still be obvious after painting (light reflection on a raised surface). If you don't want evidence of where you have worked I would consider covering it with some type of interior fabric or a pre-formed covering.
The seams need to be welded solid, otherwise the filler will crack.
'66 C60 body, '97 C6500 chassis, '07 LBZ Duramax with Allison 1000
https://photos.app.goo.gl/cxwv1C6Ay2oxYH7u7
Oh yes, all of the seams in question will be welded first
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
Interior or exterior---all the same.
52 Suburban with butchered dash:
[img]https://i.postimg.cc/FfDLGrM5/52-Suburban-005.jpg[/img]
Repaired and body filler:
[img]https://i.postimg.cc/Ty7KgkbT/49-GMC-and-52-Sub-030.jpg[/img]
Finished and ready for new holes for radio,etc.
[img]https://i.postimg.cc/s1y21dq5/Suburban-painted-012.jpg[/img]
Evan
Curmudgeon
Curmudgeon
I think I missed the boat on this one.
I was thinking of a patch like a portion of the side or top of the cab where the weld bead on the inside would be visible.
