1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 761 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 761 | I am thinking of using Bondo type filler on the interior of my cab to help hide weld seams on patch panels and such. I can't see any reason not to do that, but I thought that I'd just check with the vast experience of this list first.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Why not? It works on outer panels, and they are out in the weather. I use body filler on the interior. Work fine, last long time. Fy dolla.
| | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | Bondo is fine and if you have small seams, etc J.B. Weld can be used. It sometimes makes a better sanding surface than Bondo type fillers (which can suffer air bubbles). Also...and some may find this a negative, but I certainly don't...if you use J. B. Weld, you can use J. B. Kwik-Weld and slow the set-up time by adding slightly less than 50% hardener or you can use the regular J. B. Weld which sets up much slower. This gives you time to get things just right. With Bondo and typical fillers, I find they tend to set up too doggone fast...often while you're trying to paddle them on the metal.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Devcon has an industrial quality product that's far superior to J-B Weld. It's called "Plastic Steel". The regular stuff has a 45 minute cure time, and there's also a 5-minute quick setting version. https://itwperformancepolymers.com/...ding-repair/devcon-plastic-steel-putty-aJewrry
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | If you have a typical lap-weld with a raised bead down the seam, for strength, then you may not be happy with any of the Bondos and epoxies. This would be a panel that is visible and not something on the floor that you cover with a mat. You fill-in along each side of the bead and sand smooth and uniform but it will still be obvious after painting (light reflection on a raised surface). If you don't want evidence of where you have worked I would consider covering it with some type of interior fabric or a pre-formed covering.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | The seams need to be welded solid, otherwise the filler will crack. | | | | | Joined: Aug 2018 Posts: 761 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 761 | Oh yes, all of the seams in question will be welded first
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 |
Evan
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | I think I missed the boat on this one. I was thinking of a patch like a portion of the side or top of the cab where the weld bead on the inside would be visible.
