2 members (VicZ, klhansen),
118
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 338 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 338 | Well, I finally got the seized brake drum off and the wheel cylinder out. Now, how do I get the brake shoes off? They seem to be held in with a pin and a wrinkled looking washer. Also, if I break any of this, is there a source for new parts? I’ve never seen anything like the setup that holds the brake shoes in. At least there is only 1 spring and it seems to be in good shape.
1954 Chevy custom 261CID, T-5 5 Speed. 1952 Chevy 6400 2 ton hydraulic flat bed.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy oldieoldie, I'll try and explain, lift up on the wrinkled washer on the end that seems to be larger than the pin it is on, this should come up fairly easily. Once the end is higher than the top of the pin, you should be able to push the washer back over the pin and the washer will fall off and allow you push the pin out of the brake shoe and braketry, releasing the brake shoe. I hope I have made those instructions understandable, good luck. | | | | | Joined: Jun 2016 Posts: 338 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 338 | Sounds reasonable to me. I'll give it a try tomorrow. Thanks
| | | | | Joined: Aug 2001 Posts: 3,596 Moderator | | Moderator Joined: Aug 2001 Posts: 3,596 | I bet that 48 2-ton has just what you need. Say the word and it can be in your driveway next week! New tires are also on it!
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jun 2016 Posts: 338 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 338 | How much? If I'm considering getting it trouble, it best be worth it!
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
