2 members (sron48, Gray_Ghost), 105 guests, and 4 robots.
Topics128,078
Posts1,056,052
Members48,433
#1412448 06/03/2021 1:52 AM
Well, I finally got the seized brake drum off and the wheel cylinder out. Now, how do I get the brake shoes off? They seem to be held in with a pin and a wrinkled looking washer. Also, if I break any of this, is there a source for new parts? I’ve never seen anything like the setup that holds the brake shoes in. At least there is only 1 spring and it seems to be in good shape.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
oldieoldie #1412449 06/03/2021 2:14 AM
3B Offline
Hy oldieoldie, I'll try and explain, lift up on the wrinkled washer on the end that seems to be larger than the pin it is on, this should come up fairly easily. Once the end is higher than the top of the pin, you should be able to push the washer back over the pin and the washer will fall off and allow you push the pin out of the brake shoe and braketry, releasing the brake shoe. I hope I have made those instructions understandable, good luck.
oldieoldie #1412585 06/04/2021 1:51 AM
Sounds reasonable to me. I'll give it a try tomorrow. Thanks
oldieoldie #1412596 06/04/2021 2:38 AM
Moderator
Moderator
2 Offline
I bet that 48 2-ton has just what you need.
Say the word and it can be in your driveway next week!
New tires are also on it!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
oldieoldie #1412790 06/05/2021 5:41 PM
How much? If I'm considering getting it trouble, it best be worth it!
oldieoldie #1412791 06/05/2021 5:57 PM
PMs please.
