3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, which size must have the screws which you need to fix the engine hood at a Chevy 3600? Ask Wolfgang | | | | | Joined: Feb 2019 Posts: 4,502 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,502 | Which screws are you referring to? Hinge to hood? If so, they are shoulder bolts and are 5/16-24. Here’s a link to where you can buy them. Not sure Classic Parts ships overseas but at least you will get an idea of what they look like. https://www.classicparts.com/1947-54-Hood-Hinge-Bolts/productinfo/38%2D525/
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Not sure Classic Parts ships overseas ..... They wouldn't even ship an ignition switch to me in Alaska.  I've had good service from The Filling Station lately. I'd give them a shot. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Ok, thank Phil. This link will help. Wolfgang | | | | | Joined: Feb 2019 Posts: 4,502 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,502 | Ok, thank Phil. This link will help. Wolfgang Good, I am happy to help!
